Man of Honour
- 29 Mar 2003
- Stoke on Trent
You said his lightweight bike was easier to pedal up a hill than your powered bikes on full assist.
Basically, the assist provided by your bikes isn’t enough to overcome the extra weight. [I’m assuming here that his bike weighs less than your bikes?]
You then said, if you could afford a bike like his (lighter) then you wouldn’t need motors (heavy)
If so then what I posted above makes perfect sense - yes?![]()
Eeeeeh - maybe
The thing is that the majority think that as soon as you put a motor on, it will be way easier than a normal bike (which it is like for like).
eg Take my Trek 7.6FX, as soon as I put a motor and battery on it, I needed to put it on pedal assist 2 so it felt the same to ride.
Of course if I then go higher it makes it more easier as though the bike is getting lighter but even on assist 5 it is harder to pedal than my brother in laws £6000 Cervallo (!) so I'd have a better time just buying a very expensive bike and pretending I'm on pedal assist 7.
The only thing is I would break his bike on my commute, I won't ride my road bike on it.
