- 28 Sep 2011
- Stratford-upon-Avon
So, I am looking to build my parents a new system to replace their current 6+ y/o system that was a budget build at new.
Hopefully want to keep as close to £400 or at least below £500 for the build. I'd imagine most of the cost would go into MB, CPU and ram as I can re-use the case, peripherals and monitor.
In my head, I am thinking of using a Kaby Lake i5 (7500), but wonder if it is worth going down to an i3 (7100)? They just use it for internet (Email / FB / Banking) and some office tasks.
I know they wont need much power, but is it worth investing more into the i5 over the i3?
MB cant imagine will differ. Looking at an ASUS Prime Z270 as the z270 range is not much different in price to the Z170.
8GB DDR4 2400 ram.
Probably get a M.2 hdd for quick boot OS and a standard hdd for everything else.
Seasonic power supply (450W should be plenty).
No GPU as there is no need. Just use onboard graphics. (Single monitor use)
Any advice or recommendations would be appreciated. I always struggle to build a low end system as I try to get for the best. Then I just have to tell myself, this is not for me and all that power is not needed.
That said, the system needs to be good enough to last a fair few years.
Thanks
8GB DDR4 2400 ram.
Thanks
of cad , Ryzen would have been a nice little choice or editing .
