If your current HDMI cables are high speed then you should be ok you don't need the latest 2.1 spec cables to achieve 4k /HDR/DV i have some old HDMI 1.3 spec cables and they work fine in 4K/HDR/DV with my LG C6 OLED and Denon X2300w av amp.
Amazon basic cables are good and only cost a fiver if you do need to buy some.
I couldn’t get my old cables to work which were high speed when playing uhd Blu-ray, but oddly the ps4 worked fine, so just changed them. If we ever see 60fps movies however, then you will need to change them then
