2K build for graphic design
7 Jan 2009
Hi learned forum posters.
I have offered to build a PC for a friend who works from home. He uses Corel and Adobe graphic design software and needs a PC to handle big design files quickly. He can budget upto 2K inc VAT and needs a new monitor to go with it but that is a separate budget.
Any thoughts, especially re graphics card. Games not played, but I know some cards can accelerate some graphics design software.
Thanks
1 Dec 2015
Thanks
Any more specific details of what they do/use the programs for ? Memory bandwidth can play a big part as well as thread count / CPU Cashe for extreme pieces of work . GPU can be used as an accelerator but depends on what's used and how etc
Seems corelDraw has been coded for multicore/thread CPUs which is handy, photoshop still prefers fast fewer cores (though recent updates may have change things around and depends on what version they are using )
Reading up, larger the files on Corel, the more dependant on ram . If you able to find out how bigger files on average they are working with , but seems 16GB should be considered as standard, lower latency the better
OP
7 Jan 2009
Thanks.
Mainly Corel Draw itself and Photoshop. Files are at least a few hundred MB each some a bit bigger. I was struggling to find info on Corel GPU usage. I was looking at 32GB RAM and a 1050/1050ti?
1 Dec 2015
Thanks.
If GPU usage isn't huge or acceleration isn't great, you could be looking at AMD Ryzen 1700 8 core/12 thread of Thread Ripper 1920x 12 core/24 threads to chew through work .
Ripper might be excessive if not CPU rendering is required .
But it does have advantage of quad channel which is idea for above situations ... Just the cost of two 2x 8GB 3600hz kits are £230
OP
7 Jan 2009
I am not very up to date on AMD processors. Is the Ryzen 1700 a better bet than an i7-8700K. I see the Threadripper CPUs are expensive but maybe worth it?
1 Dec 2015
Thread ripper.
Overshot a little but 12c/24t with 3600hz ram and tight timings .
Storage is less then above
My basket at Overclockers UK:
Total: £2,101.46 (includes shipping: £14.70)​
OP
7 Jan 2009
Those two builds are brilliant. Just the sort of ideas I needed thank you.
The monitor looks amazing but I think he may need a bigger desk!
Is the GT 1030 good enough to run any GPU acceleration he may need?
Man of Honour
26 May 2012
OP
7 Jan 2009
Excellent. I will advise him to get a bigger studio too! Glad the 1030 will do as means more money for RAM/CPU. I may reduce the storage hard drive as I am setting up a NAS drive for him for longer term storage which will back up to Onedrive.
20 Oct 2002
Derby
I would add an additional nvme drive to that system as a dedicated scratch disk for Adobe. Check the sizes of files he uses and go from there. You will probably get away with a 120Gb-250Gb.
1 Dec 2015
Thanks to AMD , good time for CPU as Intel getting the hands forced :D .
Both are solid lists bit nothings perfect, tweak to hearts content . Style is a hard one to judge as well as brand loyalty etc :)
Happy building, post pics when your getting it under way so we can judge you on cable management whilst hiding the fact our own is shocking haha
OP
7 Jan 2009
Will do, but the Force is not strong in this one either!!!!
He has a big show coming up so will be a little while before I can complete it and swap out his current one. I would like to run them alongside each other for a while but he really doesn't have much space!
1 Dec 2015
Nice to do bench marks and test between. Both systems of you can. Really hits home how much of improvement it is .
Did a Ryzen build for a friend doing CPU/GPU rendering g and 3D splicing and shaves off 10/20 hours off a 5 day render
If the GPU is lacking, he can always pick up a 2nd hand 1070 unit etc . Least the core is solid in either build
