- 7 Apr 2017
Scoreboard updated.![]()
Thanks Kaapstad, thought I better put up some representation for the X58 boys
Not many 1070ti results either...
@Kaapstad - My CPU clock for the main page is: 4.4ghz, forgot to put this![]()
Could you confirm which post you are referring to please.![]()
Bench was run @ 4.6ghz, but down clocked it to 4.4ghz now
Post #539Bench was run @ 4.6ghz, but down clocked it to 4.4ghz now
Which clockspeed do you want me to use for your result 4.4 or 4.6![]()
Tried running two 1070 Ti's and was a stuttery mess (15fps @ 1440P where one TXP does 25fps). Did you have to do anything to get Sli working? Read elsewhere that SP 1.0 didn't support sli? Will have another go later1080p Extreme
i7 7700K @ 4200 - Stock Clocks
FE 1080Ti SLI @ 1885/5508 - Stock Boost
Thanks, got it working. Will try to spend some more time on it later but quick test @ 1440P (1070 Ti SLi) was 4177 with average FPS of 31.24.You need to mod the drivers for SLI and it works fine.
There is a link here how to do it
https://forums.evga.com/FindPost/2647934
