Unigine Superposition Benchmark.
14 Jan 2010
Essex
1080p Result for my New Build - Everything at Standard, but Overclocks to follow another time..
1 x Asus 1070 Strix
Core @ boost 1835mhz
Memory @ 2002mhz
Ryzen 1700x @ 3.4 Ghz
14 Jan 2010
Essex
As promised my overclocking Results follows for 1080p(Please could you update my score):
1 x Asus 1070 Strix
Core @ boost 1945 mhz
Memory @ 2152mhz
Ryzen 1700x @ 3.9 Ghz
19 Dec 2010
Ok, Here is my first Superposition benchmark on Vega 64. Happy with the results.
AMd Ryzen 1700 @ 3.0Ghz.
Vega 64 Air Stock Cooler.
HBM Clocks - 1000Mhz @ 1000mv
Core Clocks
P7 - 1632Mhz @ 1075mv
P6 - 1572Mhz @ 1000mv
Drivers 17.11.4
1080P extreme.
Sorry Kaap I am not sure what to put in for Core clocks. My P7 clocks are default, but I put the P6 state to 1582. The actual clocks in Superposition started from 1606 and then dropped to ~1590
19 Oct 2008
1080p Extreme
i7 7700K @ 4200 - Stock Clocks
FE 1080Ti SLI @ 1885/5508 - Stock Boost
Tried running two 1070 Ti's and was a stuttery mess (15fps @ 1440P where one TXP does 25fps). Did you have to do anything to get Sli working? Read elsewhere that SP 1.0 didn't support sli? Will have another go later
Man of Honour
OP
21 May 2012
Dalek flagship
You need to mod the drivers for SLI and it works fine.
There is a link here how to do it
https://forums.evga.com/FindPost/2647934
