- 6 Feb 2010
Should have really just grabbed the Cambridge Audio DACMAGIC XS V2 from RS now that they are on sale at just £39!!
The Audioquest Dragonfly red is very versatile and very hard to beat in terms of value for money. I don’t think there would be all that much in it SQ wise between that and a Schiit Modi/Magni stack and it’s cheaper and more versatile.
If the budget doesn’t stretch that far then a Dragonfly Black is still a highly competent performer for almost half the price.
Although the Cambridge Dacmagic XS at Richer Sounds is an absolute steal at that price!! Probably not as good as a Dragonfly but £39 is giving them away
There's no way that a chincey simple OP-amp based amplifier is going to be as good as a larger amplifier that is not purely op-amp based. Having said that, those of you out there buying garbage like Dac Magic... there is a certain point where all you'll accomplish is moderately distorted loudness. You won't get any of the true benefits of a headphone amplifier- fuller, richer sound. Sound that you can feel. Sound that you can reach out and touch, if you will. Will it be louder? Yes. Will it be "GOOD"? No. Maybe that doesn't matter to you, in which case I ask why you've spent more than 50 squids on headphones in the first place? I mean I really can't understand the logic of pairing 300-500 pound headphones with a 40 pound dac/amp. It just makes no sense to me. It's like the pictures you see online of people who've paired KEF LS50's with a 200 pound amp instead of a 2000 pound amp and they say they don't "get" what all the hype is about the LS50's.
HD650s are a perfect example of a headphone which, though expensive, is not prohibitively expensive, and although they do sound good with a 100 pound amp, they scale so well that if you throw them together with a 1200 pound amp, they will blow your mind.
Don't underestimate what good electronics can do for you.
I don't read too much in to opinions of audio stuff. The problem is a lot of people will write a load of hyperbole to justify an expensive purchase, almost as if they are actually trying to convince their selves how good something is rather than others. I do not believe for one minute my ears could tell the difference between a cheap DAC like a Schiit Modi and their Yggdrassil. I had a Magni 2 so will be interested to see how the DAC Magic compares although it's a diffrent product, I suspect not anything in it.
I was having USB problems with my Modi so took the plunge and bought a Modi Multibit. I was expecting subtle improvements at best but the differences were easily heard by my 60 year old ears. Most apparent was the imaging, instruments no longer played in some vague area, they were pinpoint accurate and something else that made the instrument separation even better was that each instrument had a lot more space around it (probably comes under imaging). The highs were smoother but with more detail and the bass had more grunt and all together, it was just a much more enjoyable sound. If the difference between the Modi and the Multibit is so easily heard, then the difference between the Modi and Yggy would be even more apparent.
Thanks for the heads up! Just snagged myself one.Should have really just grabbed the Cambridge Audio DACMAGIC XS V2 from RS now that they are on sale at just £39!!
