Anyone know if this impacts the IBM POWER 8 / 9 CPUs? Can't seem to find anything relating.
Not sure if I imagined more CPU use % after installing hotfix in games, but still nowhere near 100% on my 5820k.
Pretty sure that MS patch just fixes one of the exploits, and 99% of gaming is not going to be affected as it doesnt really delve into the part of the system that the patch addresses... however reportedly Denuvo will take a hammering, and potentially MMORPG type games could take a hammering, so could a lot of online gaming that is reliant on cloud computing etc.
Well I hope Intel are going to start cutting the price of their processors if we are not going to get advertised performance.
So how are firmware patches pushed for Intel products? Do you just need to update the UEFI for your motherboard or does Windows update it for you or do you need to download a patch from the Intel website or what?
Are chip firmware updates pushed through Windows Update?
Microsoft says that only systems with compatible antivirus applications installed are being offered the emergency patches. They don’t provide any further details to name the antivirus products considered to be incompatible, but say that “during our testing process, we uncovered that some third-party applications have been making unsupported calls into Windows kernel memory that cause stop errors (also known as bluescreen errors) to occur.”
Microcode updates for CPUs are generally available via a system UEFI upgrade I recall.
I think they can also be delivered via Windows Update but not sure if that method is used by many manufacturers.
Seems RyZen is exempt from the exploit in windows I think ? Microsoft published a PS script to check machine vulnerability, someone run it on I7 and 1700x
https://www.reddit.com/r/Amd/commen...ttings_ryzen_vs_i7/?utm_source=reddit-android
