If you are looking for like minded people you should go hereIndeed, but I like to see other people views of him. It seems I am not alone.
link
Congratulations - but that's not what the video is about.
The tech industry publishing benchmarks and ranking things solely from systems driving components far above published specifications is the problem.
So ppl with 8400 and 8700 do you get your max boost all the time? I don't know, I don't have one just curious how it looks on normal mobo and average cooling.
Probably true though... Certainly quickened intel release schedule but they would released a hex core consumer CPU around now anyway as they would/ were rapidly running out of ways to offer an even slightly compelling upgrade of their own products never mind AMD's
What MB and cooling do you use? How long did you test it for?
Calm down, i meant to quote this:
which everyone should know anyway.
Ultimately, it doesn't matter though. All that this proves is that poor cooling/power supply can throttle components...which everyone should know anyway.
It isnt "con lake", it works exactly as advertised. I have now had machines with both an 8400 and 8700 (non k) and they hold the full specified boost just fine.
Adored will kiss his own arse whenever he gets the chance. Ignoring that though, it's intriguing at the least. Intel now rate TDP at the base clock, reviews all review the CPUs with boost clocks. Pre-builds that are limited in cooling capacity and built to Intel's own specs, ie 65w TDP in this case, will then underperform against reviews. It's not very honest is it ?
Ok thats fine, but what about reviewers showing xxx performance when you are more than likely to get xxx - 20 odd % with most builds (well OEM stuff i would expect)
Its fine benching a cpu or gpu (or anything) showing best case performance but come on we really should be seeing the performance under average build setups as well.
So are you both saying that because enthusiast/pc builders know that you should use proper cooling on CPUs to maintain boost clocks, the low base clock (compared to the max single core frequency) of the 8700 and 8400 is acceptable practise?
In what way? People should research their purchase more. Just a brief read of this and everything is clear -
https://www.intel.co.uk/content/www...ology/turbo-boost/turbo-boost-technology.html
https://www.intel.co.uk/content/www/uk/en/support/articles/000005641/processors.html
There is no con, everything is written in black and white.
I'm not sure how any of that computerbase review proves Adored right, but that's Adored for you.
OEM cheaped out on cooling and power supply so the 8700 TBT can't really boost to the maximum all core boost, that's pretty much all there is to it. I do think Intel should have some stricter guidelines for OEMs so you don't end getting sub-par performance due to OEMs trying to cut corners.
I'm saying that no one should buy some **** box medion PC and expect it to perform in the same league as one from a better oem just because they both headline with the same CPU...
The problems not Intel CPU's here but a rubbish oem computers...
Or course Intel are engaged in some marketing BS with lots of talk of 'up to' performance figures and hiding the potential shortcomings of all core boost speeds...
Story is the old Latin phrase.... Caveat emptor
