Is this done on my PC?Most routers (even the very basic ones that your isp gives you) will show you a list of connected devices. Go to the router home page and have a look at a few of the options.
Yes, generally speaking your router will have have an IP like 192.160.0.1 that will allow you to log in via a browser.
Just so you're clear as possible do the following
- Find your router
- Check it for a label which shows admin login and password, and IP address
- If you don't find it, google your make and model of router for details
- Open a new window in your browser via a machine connected to the router via wifi or Ethernet
- Enter the IP into the address bar. E.g. Type : 192.168.0.1
- It's very likely you'll require administrator login details to access these settings, they should be on the label. If you can't find them google as you did for the IP.
- If these don't worry they may (and frankly should) have been changed. If you can't work out these login details, you'll have to factory reset the device
- Once successfully logged in, change your username and password to something memorable.
If you’re using Windows then 9 times out of 10 you can type ipconfig /all at a command prompt and the default gateway shown will be the IP address of your router.
