So to confirm, this is the exact same item i need correct? -
https://www.hellasdigital.gr/tv-and...-a3-adapter-hdmi-in-hdmi-out-rca-and-toslink/
thanks for all the help
Yeah, looks like the same unit but a different brand. That's not surprising. A lot of this stuff comes out of the same factory and is just badged up for different markets, or just different brands for the hell of it.
If you have chance to check with your supplier (Athens? / Crete?) to confirm, but as far as I can tell from the specs of the rain forest one it'll pass Bitstream audio which means DD and DTS.
You might want to have a look at the Samsung when you get the de-embedder and check it does DD/DTS for the Optical input as well as off disc. I suspect it will but can't be 100% positive as it's not explicitly stated in the manual. ProLogic II is mention though. My guess is that DD and DTS will be auto-detected, whereas DPL II is an optional choice between that and Samsung's own EQ or plain stereo playback.
Edit: re older PS4. Yeah, you're right. It wouldn't make a difference.
Optical maxes out at DD/DTS so for HD Audio you need HDMI out going direct to an AV receiver so it can get the higher data-rate signals for Dolby TrueHD and DTS Master Audio. That also means that the Samsung is incapable of decoding HD audio. It needs a whole gear change.
I'm not a gamer so forgive me if if I'm a little behind on the latest games, but The Last of Us Remastered and Battle Front 4 are reputed to be very good for sound and they make use of HD audio too. Drive Club is also mentions. When you're ready to make the move to a full HD-audio decoding AV system then they'll be some games to start with as tests.
@hornetstinger - While your comments are valid re a used AV receiver and HD Audio etc it's not always the case that the enquirer is looking for that type of solution.
In this situation it sounds like this might be a second property, so the requirement is just to get something working with the gear already on-site. There may be other factors we're not privy to as well.
As for losing HD audio, my guess is that if the PS4 was playing through the projector- or TV- speakers then
@chris_r never had HD audio to begin with. Gaining the use of the surround system and DD & DTS will be a big step up for a relatively small outlay. That's a good day's work in my book. Maybe some time in the future it'll be the right time to pull out the Samsung and replace it with a proper AV receiver / speaker combo, but that day is not today.
