- 29 Jan 2003
According to the following, Defender should have added the registry key. When you go into Defender is it possible to check for updates to see if Defender needs to update, then recheck the registry to see if it has set the reg key?
https://support.microsoft.com/en-sg...ndows-security-updates-and-antivirus-software
Oh I tell a lie, it is there (didn't show up when i searched for it for some reason).
Just tried it again - same result. I'm getting error code 0xc00000bb which is apparently related to NVME SSDs and they're promising a fix for end of Jan (well they promised that in December but I'm guessing they might have bigger fish to fry now!).
Thanks for the advice though man :thumbs:
