Prefer a subaru. Wouldn't touch that if it was cheaper.
But, I definitely wouldn't spend 6-7k on one. There are many much much better cars available for that sort of money. Especially if you only tend to keep it for a couple of years, you don't want to find yourself in a position where you can't move it on.
I could probably get one cheaper then that and put a small fund anyway for when or if it breaks.
I'm just finding it difficult to find another car which can be as practical with similar performance and cost.
In short does anyone feel it's worth the effort to get one? Or should I dismiss the idea.
