Pay the extra and go bold - orange or yellowFinal Spec submitted.
Secured a build week of week 8, so hoping to get it at the end of March.
- Misano Red
- Black Leather
- Virtual cockpit
- Carbon dash inlays
- Flat Steering Wheel
- Misano Red
- Black Leather
- Virtual cockpit
No, you need the order number and a login to yourAudi.Had a letter from company supplying my car with chassis number. Is there any way to track its build and shipping from this?
I’ve never used it but you can create an account here then use an order number and postcode to track your order.
https://www.audi.co.uk/content/audi/youraudi/youraudi-login.html#/learnmore/landing
The one thing you at least know is that it’s reached build if it’s got a chassis number. Likely somewhere between 3-6 weeks away, needs to traverse quality control, transport (transport to Emden, waiting for a ship, transport to port of entry) and post arrival check, before being transported in the UK to the supplying dealer.Thanks I've contacted the broker to try get the order number.
Looks awesome !!!Have had my new car for a few days now after a less than ideal start - gearbox mechatronics unit failed on day of delivery. 5 weeks later it is back so we start again! Came from a F30 330D that was trouble free for 4 years and 130K miles so hopefully no more issues.
A4 Avant 2.0 TFSI SLine in Mythos Black with the technology and comfort and vision packs.
Told you they were a laugh!So it turns out the S1 is indeed a hoot to drive! Engine/exhaust note isn't too bad, although I was surprised by the lack of crackles and pops. Although having heard the wet farts an A45 AMG makes, I suppose it's not the end of the world..
I was also genuinely surprised as to how compliant the ride was, especially compared to my old 8P S3! Fun little machine; 3rd gear is brilliant!
Challenge now is to convince my bank manager to lend me the dosh![]()
I was thinking the same with mine. I’ve had trim wrapped before which was ok but not perfect. I don’t fancy the stick on trims from eBay so was thinking to try and got hold of the carbon atlas panels but can’t find any on the bay.
