Budget Gaming PC Build
27 Jan 2018
Hi, I want to build my first gaming PC and i've picked some parts but haven't yet ordered anything, What do you think of this list and is there anything I should change?
Processor – AMD Ryzen 5 1500x
Motherboard – Asus STRIX B350-F ATX (don't really care about the RGB but lots of people say its good)
RAM – Ballistix sport LT 8gb stick 1x (Is 2x 4GB sticks better?)
SSD – Samsung 850 EVO 250GB
Hard Drive – WD 30EFRX 3TB (already own this)
GPU – MSI GTX 1050 ti gaming x 4GB
Power Supply – Corsair VS450W ATX
Monitor – AOC G2460PF OR Asus VG245H
Case – Corsair 270R windowed Mid-tower ATX
My cousin also has a used i5 6600k which he would sell me for £100, is this better than the Ryzen 5 or does the ryzen 5 perform better, I have a budget of around £850 but already have peripherals except monitor. I don't need it to be VR ready but want to play things like fortnite or forza horizen 3 at 1080 medium settings at 60 FPS. If you have any better suggestions please let me know.
Thanks
1 Dec 2015
My basket at Overclockers UK:
Total: £845.48 (includes shipping: £12.60)​
For better GPU and pre-built
Total: £894.88 (includes shipping: £15.90)​
OP
27 Jan 2018
recommended gpu is a 970/1060 fyi.
your budget is a bit too low currently to get the recommended gpu new, unless you source a used 970
I can get a used MSI gtx 1060 6gb gaming x used on ebay for around £300, my cousin is selling a gtx 1070 8gb for £350, how much better would that be than the 1060 and would it fit into this build? Also which would be better to use, i5 6600K or the Ryzen 5 1500x or is there something else i should use. For the monitor i know someone who can get me a very cheap monitor which will do untill i get enough money to buy a better one. And i know a 100% Legal way to get windows 10 home for free with just a few missing features which will save me about £100 to start with. Thanks
Man of Honour
26 May 2012
that's not much cheaper than a new one, and you don't get the benefit of warranty
an okay-ish price currently
the 1070 is about 30% faster than a 1060 6gb - if you can get it for £350, you should - i'm assuming that your cousin will help you out should you need to use the warranty
*ALTHOUGH*, that being said, that will only leave you £500 for the other parts.
something else. the 1600 in @orbitalwalsh 's spec is the one i'd recommend.
*AGAIN ALTHOUGH* unless your cousin is selling the 6600k with a heatsink and motherboard - and it has to be less than £250 for it to be worth considering. the reason is that the ryzen 1600 + mobo costs £250. and this is better value than a 6600k + new mobo + cooler.
so unless you can get a good deal on the 6600k spec, the obvious choice is the ryzen 1600 (4c4t on the 6600k vs 6c12t of the 1600)
OP
27 Jan 2018
What do you mean by heatsink? He says it comes with a cooler and he does have a motherboard (Asus H11OM-R) which he could sell me for £25 but i read that thats not much good. So should i get the 1070 8gb from him and then get the ryzen 5 1600 and Gigabyte GA-AB350? (How many USB ports does that have?) Or is there a better motherboard than that which i should go with? And then get 8gb ram and an SSD and then i'll be set
OP
27 Jan 2018
Also how upgradable would this be in the future? And should this be able to play Forza horizon 3 at mediam-high settings at 30-60 FPS?
I'm playing fortnite at the moment quite a lot but i want to replay subnautica as well now that its fully released and i'm looking at getting overwatch and forza horizon, would this system be able to run these games well?
Man of Honour
26 May 2012
heatsink = cooler. same thing, different names :p
correct, it isn't and it won't allow the 6600k to be overclocked. you'd be looking at a new mobo ~£120 to pair with that cpu. also, the stock cooler that comes with the 6600k is terrible, so you'll need to spend another £35ish to truely unlock the cpu's potential.
again, your budget isn't enough :) you'd be looking at >£1000 total spend
(1) 6 on the back, (2) no this mobo is fine.
amd is committed to supporting the socket until 2020, so it's a case of dropping in the new cpu after a bios flash in the future
depends on the graphics card. paired with the ryzen 1600 - 1050ti, probably not/just about. 1060, yes. 1070, yes.
forza is the most demanding game that you've listed. so the other games will run better.
#walloftext lol
OP
27 Jan 2018
#walloftext lol
So should i get ryzen 5 1600 with Gigabyte Mobo or intel i5 6600k and find a different mother board?
#walloftext lol
I think that if i just get a crappy monitor and windows 10 for free i should be fine
£350 – gtx 1070
£250 – ryzen and Gigabyte Ga-AB350 5 OR i5 6600k and Mobo
£80 – £100 8gb DDR4 ram
£80 – samsung Evo 250gb 2.5 inch SSD
£60/70 – Case
£25 – Corsair 450W power supply used from cousin
Hard drive i already own.
I can probably ask someone i know who works with computers to lend my a monitor for a while for free
Total: £850
How does that setup sound?
Man of Honour
26 May 2012
1600
that's cutting it close with a 1070 in the build. honestly. recommend 550w.
sufficient for now, at least it'll be an easy upgrade to drop in another 2x4gb sticks in the future for 16gb ram :)
very decent :) except for the psu wattage.
OP
27 Jan 2018
1600
should i get x2 4GB sticks or x1 8gb stick, i've heard that x2 4Gb sticks is better but it gives me less upgradability cause it uses up 2 spaces instead of 1.
1600
How much would a 550w cost? and will that give me enough power to upgrade in the futute?
OP
27 Jan 2018
1600
I looked up EVGA 550w power supply, do i need a Supernova 550 g2 for like £82 or can i cheap out and just get the 600W1 White for £45? It is 600W instead of 550 and it is so much cheaper, it only has 3 year warranty instead of 7 but how much better is the g2?
Man of Honour
26 May 2012
correct, but the board has 4 ram slots, so it'll be an easy upgrade to drop in another 2x4gb sticks in the future for 16gb ram
so not an issue. get 2x4gb sticks
the cheapest one i'd recommend is
Total: £75.49 (includes shipping: £10.50)​
but as you can see, it's quite a bit dearer
OP
27 Jan 2018
Man of Honour
26 May 2012
the evga 450bt, is okay, but underpowered for your build with the 1070 - and the same wattage as your cousin's psu
i'd avoid the evga 600w you mentioned :)
