Permabanned
- 12 Sep 2013
- Knowhere
Again, that's exactly what I presumed you'd be doing as well, the only real problems I've heard people having with HBCC is when they're using mGPU setups.
I'd advise you to just leave it on and enjoy a crucial Vega feature, and btw, I remember seeing some very recent Computerbase.de (?) or some site testing GPU's in 2018 where they exclusively tested HBCC, and from what I remember, it had the biggest advantage in 1080p. 1440p and 4k were near identical if not a +0.5-1.5 fps gain, so don't miss out on it because of some early drivers/reviews and performance gains/losses you're not gonna feel anyway.
I say this because I presume you're a max everything play at moderate frames ultra settings (or increase texture resolutions to match your preferred fps, for me its 45-50), and you would really see a GREAT benefit there.
For e.g I've been recently playing R6 Seige (w/ 70% Render Res ,where 50% being native) and Injustice 2, Wolfenstein 2 w/ 6k textures all of them utilizing 8-10GB Vram and I've not felt any performance loss whatsoever. It's a feeling you don't want to miss out because of some near-inconsequential things. I'll edit my post with the article once I find it.
Edit - Here are some recent articles
GN - "
In the interim, there’s really not much reason to disable HBCC, and it occasionally provides a 0.5-4.0% performance increase. Limited system memory would be a reason, of course. It might be worthwhile to enable HBCC and just leave it in the background, hoping occasional uplift will emerge. We can only speak for the applications which we’ve tested, naturally, and there’s potential for HBCC uplift in production applications (untested) or memory hog games (user mods for Skyrim and FO4, for instance, are often VRAM pigs). In the event you encounter one such game, HBCC enablement could help; of course, if stability or system RAM issues are encountered, there’s obviously not much loss to disabling HBCC, either." from here
Here's another from PCGH.de
" All the bigger was our surprise, as it was here that the Radeon RX Vega 64 was able to gain a staggering 11% and 14% respectively - depending on the driver used.
In the other tests, the result was more mixed, but apart from a single 3% drop in min-fps we were able to measure a (very) low performance advantage through the bank. This may, depending on the game, logically different behavior - problems occurred in the test as I said but not on. AMD will continue to drive the driver in the future and even if it should be our prime example to an outlier, it is likely that one or the other percent of gaming performance by better understanding of the possibilities offered by the HBCC and corresponding optimizations are quite in it.
In the meantime, the hot tip for all Vega owners is: Activate HBCC in the RSCE Control Center, click Apply and restart the computer once for safety" SOURCE
Thanks for info and links, As suggested I'm going to turn it on and see how it goes for a while, If I'm having no issues with the games I play I'll leave it on, Cheers.
