I'm toying with the idea of the Abarth 124 Spider but that's considerably more expensive£13k for something small and sporty?
I’d get this personally
http://www.autotrader.co.uk/classified/advert/201801132728868
Well the Up GTI will map to around 135 (based on what people offer for the 113ps Octavia 1.0) and will still include the uprated brakes, 6sp gearbox, steering rack, suspension adjustments and various styling tweaks that the 90ps Up won't have.Not massively impressed, the 90PS UP TSI has more than 113PS with a simple re-map, and its cheaper...
135PS~ would have been nice.
Once you’re in it with fuel it’s weighing nearly 1200kg, so less than 100bhp per ton. Add a passenger and it’ll be just the same as any other low powered small hatch.
Depends if you want a broken back or not reallyProbably better off with a used Fiesta ST tbh.
Depends on your usage I guess. I'd take my RS133 Twingo if I'm just nipping around locally versus my RS200 Clio.
Little cars with a poky engine are great fun for that sort of driving, but any sort of distance and the Clio is much better with 6 gears and cruise control and all that jazz.
The Up GTi has 6 gears and cruise control (option)
This was the car I'm considering when I raised the question about wraps/cemamic coating...tempted by the red with black roof and chucking a load of options on. Quite a major downgrade from my 208 GTi by Peugeot Sport but I don't need all that power, and much cheaper to run.
by Peugeot Sport.... Did you need to add that in there..?
Yes it's actually a slightly different model/trim to the normal 208 GTi
113bhp and 9 seconds to 60. Doesn’t seem fit to wear the GTI badge. Especially when something like a run of the mill Fiesta with the 140bp 1.0T engine choice in will be just as fun and have the same 0-60 despite the fact it’s heavier.
I know power and 0-60 isn’t everything as it is obviously just a fun little city car but being a GTI it should be quicker in this day and age when the not much bigger Polo and Fiesta have around 200bhp and hit 60 in the late 6’s I would choose a used one of them any day over a new Up if I was after a fun little roller skate
