Mine did - 1960s council house. It recommended a specialist damp report which I had done with Peter Cox. This was after I'd done some research and found out about all the potential for fraudulent damp reports and recommendations for expensive unnecessary remedial works.
The damp survey came back to say that on the ground floor, about 50% of the external walls and one of the internal walls were suffering from rising damp, and recommending a new DPC being injected (by them), and all the internal walls having the plaster stepped and re-done using their specialist damp proof render. The upstairs was also reported to suffer badly from condensation, which I'd already seen when I viewed as one of the rooms was being used to dry clothes with the window obviously never being opened
So I moved in and I thought I'd get the place stripped, ventilated and heated for a while before considering whether it needed anything doing. In the lounge/diner the carpet was damp in a number of places and there was thick vinyl wallpaper on the walls. Stripped it all and on the blocked up chimney the plaster was soaking wet
The air vent was completely blocked and the wallpaper was waterproof so the wall obviously couldn't breathe at all. Within a week it was dry and there's no evidence of moisture coming from anywhere else. All signs point to it coming in from the chimney and tracking along the carpet. I'll get a better chimney cap fitted just to be on the safe side but the vent is working fine for now. Upstairs is also completely dry.
Tl;dr survey said rising damp, I ventilated and heated and now it's fine.
