- 14 Oct 2007
- newcastle
4x8 mate, it worked at its rated speed 3200mhz with my 1700 so hope it will be ok with my TRWell playedIs your ram 4 sticks? or 2 x 16?
He's talking about Pinnacle Ridge, which is due in April and on 12 nm. "Zen 2" cores on 7 nm, which are expected to feature up to 6 cores per CCX, won't be around until next year.
Yes they are generally good but cut corners for TR unfortunately so not recommended.
My mrs relented and let me change the chip for a 1920x
MUCH better option. No point going to a 8 core threadripper. If you're going to "Rip" it, then more than 8 cores is the way forward![]()
Mate what temps do you see on your chip? I’m seeing 75c @3.8ghz 1.36v and cant get anywhere near 4ghz on my custom loopYou might want to check reviews of water blocks too, the EK doesn't review well.
I’m at 1.38v trying to get 3.9 stable but falling at the minute, what do you have your soc voltage at? Do you use LLC if you do what setting? I have used the cross method for the pasteWith 1.35V on my 1920X running at 3.975GHz, my ek block manages to maintain 75 degrees under prime in place fma3 testing. Initially, it was getting up to nearly 90 degrees as the first attempt at applying thermal paste was evidently poor. I used a large blob in the centre of the Z in ryzen on the ihs.
I think I might have 3.9 stable at 1.38v in the bios, soc is 1.25v and set LLC to auto, max temp was 77c. I’m a little disappointed not to get to 4ghz especially seeing most chips hit 4ghz at 1.35vVcore is set to 1.325V (custom p-state vid of 24 & fid of 9f)
Vcore soc is set to offset +0.01250V (gives 1.128V)
CPU Vcore LLC is set to low
This is on a gigabyte gaming 7 board.
What are your stress temps at 3.9?That 100Mhz will make little to no difference, don't worry about it. I've had mine up to 4.2 and for the extra performance offered up it's not really worth it, I just leave it at 3.9 with sensible temps and volts.
