Permabanned
- 22 Aug 2004
Bit boring but whats a good cooler for a rig thats on 24/7 im using a corsair hydro h60 that i used to run a 3770k on, its errr a bit hot with the 8700k.
Using a CLC as intake in a system that uses air cooling on everything but what CLC is on means everything but what CLC is mounted on runs hotter. So yeah, if want your case to be an oven for all the air cooled components thus making them all run hotter so your CLC cooled component is a few degrees cooler then by all means use radiator as intake.Depends really on how that cooler is configured. Have you got it set as an INTAKE to the system, cus if you haven't that alone could knock 10 degrees of the temperature. Changing the fan for an ML PRO and re-writing the fan profile under LINK could change the system a little bit too. Failing that then I would get a larger radiator. An H100 or something similar.
A graphics card will turn a case into an oven anyway. After an hour of gaming the graphics card will start to run hot and dump it's heat into the case. If you have a top mounted exhaust radiator then guess where all that heat is going to pass through. Your radiator!Using a CLC as intake in a system that uses air cooling on everything but what CLC is on means everything but what CLC is mounted on runs hotter. So yeah, if want your case to be an oven for all the air cooled components thus making them all run hotter so your CLC cooled component is a few degrees cooler then by all means use radiator as intake.![]()
Maybe your cases but not any of mine or anyone who sets up their case to flow air properly. My case airflow into CPU and GPU coolers is normally only 2-3c above room ambient and never more than 3-5c above room ambient even with both CPU and GPU simultaneously running stress tests ,, be it 10 minutes of 10 hours the airflow is always less than 5c warmer than room .. but then all of my systems have case airflow tuned to components used.A graphics card will turn a case into an oven anyway. After an hour of gaming the graphics card will start to run hot and dump it's heat into the case. If you have a top mounted exhaust radiator then guess where all that heat is going to pass through. Your radiator!
It doesn't matter where you put a radiator. On the front as intake means it might mean the starting temperature is 2°C higher, as an exhaust then it will not obstruct cool air comngc in up until the point that the temperature of the graphics card starts to saturate the radiator and start cooking the processor.
It's just not worth getting into a tizz over where to put the radiator in a CLC system. With hindsight I wouldn't have bothered with one for a CPU anyway. The number 1 component you need to keep cool is the graphics card.
I do agree, putting a CLC on CPU .. and that GPU cooler is the problem child, not a decent tower CPU cooler .. but it's not just GPU that needs cool airlfow to keep cool, it's all components in the case.
I'm not in a tizz. Seeing as I install ventilation systems and heat exchangers for a living I think I've got just a bit of a clue how air moves around and gets warmed up and cooled downMaybe your cases but not any of mine or anyone who sets up their case to flow air properly. My case airflow into CPU and GPU coolers is normally only 2-3c above room ambient and never more than 3-5c above room ambient even with both CPU and GPU simultaneously running stress tests ,, be it 10 minutes of 10 hours the airflow is always less than 5c warmer than room .. but then all of my systems have case airflow tuned to components used.
It definitely matters where you put a radiator, what fans are used, what speeds they run, etc.
You are the only one in a tizz.I do agree, putting a CLC on CPU .. and that GPU cooler is the problem child, not a decent tower CPU cooler .. but it's not just GPU that needs cool airlfow to keep cool, it's all components in the case.
having been friends with Alphacool for a while my ideas of pcs and such have been brought crashing down to realityUsing a CLC as intake in a system that uses air cooling on everything but what CLC is on means everything but what CLC is mounted on runs hotter. So yeah, if want your case to be an oven for all the air cooled components thus making them all run hotter so your CLC cooled component is a few degrees cooler then by all means use radiator as intake.![]()
Or is it better to have the CPU run a couple of degrees warmer so the GPU gets cooler air and runs cooler?Yes, you are right, it's swings and roundabouts. If you have it as an exhaust then the CPU will be hotter, if you have it as an intake then everything else will be hotter. Think is though that your CPU generates less heat than your GPU so generally it is better to have the CPU cooler as an intake. But it all comes down to volume of air. The more air you have going through the radiator the lower it's temperature of that air ( diminishing returns of course, because it won't go lower than ambient! ) and the less effect it has on the rest of the system.
There is also the diminishing return of noise level .. hopefully below the level where ears start to bleed.
Honestly, a decent case with good venting and fans make it rather easy to have good cool airflow to both GPU and CLC coolers / radiators.
But if I had to put a CLC in any of my systems I would choose to put it on a high wattage GPU rather than on CPU.![]()
I hadn't really thought about that. Same temp range issues could be problematic with AMD CPUs. But as long as CPU and GPU cooler / radiator are getting air within 2-3c of room ambient everything is cool, pun intended. And as long as case has decent airflow design (enough intake/exhaust vent/airflow area with good case fans supplying air less than 3c warmer than room is not all that hard to do. Here is a basic tutorial for case airflow I wrote up a few years ago. Still applied to today's cases.depends on GPU, but pascal and vega- very sensitive to heat because of their Boost system works - cooler the better performance
