I'm currently running a Gigabyte GA-870A, AMD Athlon X3 440, 8GB DDR3, AMD Radeon 6800, and a Corsair HX 450W. Bought most of it in 2009/2010 and it was already relatively old by then. Totally ancient by today's standards. I got a legit copy of Windows 10, a Dell Ultrasharp U2311H monitor, and a USB3 Wifi adapter that are probably the only things that'll still be usable.
Use is mainly light gaming (decent quality preferably but don't need ultra high def/fps) and some CAD work. Generally something that just works and is responsive. Anything in the current midrange will be a vast improvement on what I have now so hopefully a budget of £600 to £700 will be sufficient, although I'd prefer it to be at the lower end.
This is what I've spec'd so far, any advice would be greatly appreciated!
Main thing I'm struggling with is the PSU. The online calculators tell me I'd need a 650W PSU (for when I get the 1080ti) but I don't know which one to choose that won't blow my budget.
Any suggestions on a PSU or any parts that I should swap out?
thanks in advance!
- Ryzen 5 1600 (will use the stock heatsink)
- ASrock a320m Pro 4 (cheapest 4xDIMM AM4 board I could see)
- Corsair Vengance LPX 2400 2x4GB (will get another 2x4gb sticks if it turns out I need more)
- 256 WD Black M.2 NVMe (willing to spend a little more for NVMe to make the OS faster)
- 1TB Seagate ST1000 SSHD (for storage. Debating if I need a hybrid drive or if a standard will do)
- A full size 1050ti of some sort (don't know why but don't like mini cards. Plan to upgrade to a 1080ti when prices drop to reasonable levels or if the 1050ti begins to struggle)
- cheapest case that will fit everything (don't care how it looks)
thanks in advance!
4 years, we should be on one generation of card after the incoming one this year , maybe two - mid range cards should be hitting 4k gaming nicely
