Im at a crossroads,,
Im planning on getting a mobo/cpu/ram upgrade done this week as my motherboard is failing on post
takes me about 45 minutes to get it to boot, it powers on then powers off 2 seconds later then does that over and over sometimes i will see the boot process led go through different bootup post codes then it will power off again and reboot and this time nothing on the lcd showing it booting up then it will power off again rinse and repeat..
Gigabyte Z97Xoc Force board
with 4790k @4.8
once the system does boot it will work perfectly until i shutdown then same crap again lol
anyway i think the motherboard has issues
hence really needing a mobo/cpu/ram upgrade as z97 takes DDR3 so i would be requiring DDR4
what would you go for, im getting told over and over by people that 8700k is the choice with z370mobo
but ryzen 2 has just been released and its not so much the cpu im interested in funnily enough its the motherboards x470 motherboards look great.. and 2700x does not look like its that far behind intel this time and seems the memory issues that where there with the 1st gens are almost ironed out.
so im in a bit of a dilema what would you guys go for
i dont mind going either way im not tied to intel or amd as in being one sided......
with 4790k @4.8
