- 18 May 2010
- London
@8 Pack
Please help.
Before purchasing the 8 pack Team Group 3200MHz ram my PC was stable.
I was running 1.35v on my 1700 @ 3.8Ghz. Happily stable since Sep 2017.
I bought the 8 pack ram a few days ago. Reset my bios to defaults set the DOCP profile applied my cpu overclock and played away. Within 20 mins of either BF 1 or Assassins Creed Origins game freezes but windows is OK.
The first thing I did was verify the ram worked. I reset the CPU to stock and applied the DOCP profile.
I played about 4 hrs with no issues.
Next thing I did was with RAM OC in place, I tested my CPU. Eventually by upping the volts from 1.35v to 1.36xx it passed 3hrs in Prime 95.
However I am still experiencing lock-ups when I play games.
I have been slowly upping the SOC so far up to 1.15v and still no luck.
I tried setting the SOC back to auto and applying 1.4v to the ram, still lock-ups.
I tried setting my CPU to 3.7Ghz and using the DOCP at default settings but it still locks up.
Why is my CPU and RAM independently stable but not together?
Any ideas?
With the CPU OC in place, as a test should I set my DRAM to 1.4v and the SOC to 1.2v to see if it is OK?
Because if that doesn't solve the issue then I don't know what will.
Edit.
I tried 1.2v on the SOC and 1.4v dram and still locks up.
This was with my CPU at 3.8Ghz which as I said above independently is stable for 3hrs in prime 95.
Please help.
Any ideas?
Edit.
