Hi guys
I have an old single garage with pitched roof, single brick etc and was wondering if you could help me with semi insulating it. I'm not wanting to go all out and if anything id like to insulate the roof and the garage door from a lowering the temperature in the summer point of view. (I use it as my garage)
So one end looks like this above the garage door:
https://1drv.ms/u/s!Ao-uc7LjK88EgdVrncWVCWYBw0u1Kw
And the roof itself looks like this:
https://1drv.ms/u/s!Ao-uc7LjK88EgdVpaWSdtFmjAVWL4A
Am i right in thinking that i can just get that celotex stuff, cut it to size and whack it in between the joists with small wooden cross beams to hold them in place? Or is it something more complex than that? The garage door is also a big radiator but i believe i've found the right insulation to stick to that to rectify that issue. I may also paint it white from the outside to also help with reflecting the heat.
What do you guys think? On the right track?
Thanks
Thanks
