- 7 Aug 2004
As title, Im curious if the new 15" MBP will have a 6 core i7 - what do you think the chances are?
I don't think they've been officially announced... but these are the likely details:
https://www.anandtech.com/show/1207...on-processor-lists-leaked-coffee-lake-refresh
Interesting...do the Macbook Pro 15" have 45 watt processors? Im unsure in the new chassis design, if so the i7 is looking promising.
Have you guys seen the 8th Gen with Vega graphics processors?
https://www.anandtech.com/show/1222...-core-with-radeon-rx-vega-m-graphics-launched
65W and 100W options but that includes the CPU and GPU, so thermal envelope probably not that different to an MBP 15 with discrete graphics. I wonder if Apple will end up using these and stay at 4 core for the MPB 15 range?
Rumor has it that the top end 15" with have the new i7-8809G which is 4c/8t and RX Vega M-GH graphics, and they will be using DDR4.
Razer's new Blade laptops have been announced recently. They have 6 core Intel CPUs in them, and the laptops are very Macbook in form factor. So I expect if Razor has had access to them long enough to develop laptops, Apple will have too.
I'm actually in a similar position. I'm tempted by a Macbook pro, but not the current iteration.Look interesting - but a smaller battery compared to gigabyte - so the gigabyte is more appealing.
Basically I'm gonna buy the gigabyte or the new macbook pro for full time photo video work.
Apple has its work cut out - the gigabyte is technically perfect specs wise for me - 100%aRGB 4k screen, 6 core, 32gb ram and I can upgrade the ssd's etc and a large battery.
Apple needs to match it specs wise - 100% adobe RGB screen 6 core etc- but also it needs better power management and longer battery life (should be dooable given apples focus on power use) - id sacrifice 'unplugged performance' for a longer battery life - but as long as it went as fast as the gigabyte plugged in.
Also OSX appeals to me and the software integration of my mobile devices etc.
Its a tough one, I'm not sure apple will pull it off - but I am gonna hold out for it as long as they release it by the end of July - otherwise with my work schedule I will have to buy the gigabyte anyway.
