- 1 Dec 2015
@tamzzy Thanks again!
I realised I don't have a wifi card, so changed the MB:
My basket at Overclockers UK:
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £164.99
- 1 x Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit - Black/= £188.99
- 1 x Bitfenix Formula Series 550W 80 Plus Gold Power Supply= £66.95
- 1 x Gigabyte GeForce GTX 1070Ti Gaming 8192MB GDDR5 PCI-Express Graphics Card= £439.99
- 1 x TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive= £99.95
- 1 x WD 1TB Blue 7200rpm Internal Hard Drive (WD10EZEX)= £39.95
- 1 x Kolink Stronghold Midi Tower Gaming Case - Black Tempered Glass Side Window= £35.99
- 1 x LG 24MP59G 24” 1920x1080 IPS 1ms 75Hz Freesync Widescreen LED Gaming Monitor= £149.99
- 1 x Gigabyte X470 Aorus Gaming 5 Wifi AMD X470 (Socket AM4) DDR4 ATX Motherboard= £159.95
thermal grizzly £5 and if you want to save a little, get 8 Pack 3200hz version as more mature Bios will come out that will handle 3600+ speeds. just makes your life a bit easier to start with
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
and personally would push this screen for a little more! 70Ti on a 75hz screen at 1080p.... its'll be able to push higher !
https://www.overclockers.co.uk/aoc-...z-1ms-gaming-led-monitor-black-mo-024-ao.html
that or a 1440p 60hz screen
https://www.overclockers.co.uk/acer...itor-silver-black-um.hh7ee.018-mo-128-ac.html
gtx 1060 6gb would be batter match for 1080p 60/75hz
also you've saved £20 on 70ti Gaming being on sale today and £9 saving in ram. know you've upp'd the board but the 144hz or 1440p screen is really worth it with that card!
also, worth while to make most out of the 2600
https://www.overclockers.co.uk/cryorig-m9a-single-tower-heatsink-for-amd-hs-00b-cy.html
