What's the correct desk posture?
14 Apr 2014
Hampshire
For the last 2 years I've been at university, I've always had the crappy desks you get with student accommodation - fixed height and quite high. I bought a proper desk chair at the beginning of this year, and I've managed to get my posture in line with what you see online - arms at 90 degrees etc, but I get tremendous pain down my forearm, wrist and hand from using the mouse. It's now at the point where I don't ever go on my computer - I sold my GPU a month ago or so, and haven't missed it at all.
It's only getting worse too. The pain distracts me from being able to work; I spend most of my time trying to get comfy.
This is quite confusing for me, as it goes against everything I've learned about desk posture - I've got a humanscale desk chair which cost me a fair bit of money, have corrected my posture, and yet my pain is getting progressively worse.
Is there much I can do? Getting a new desk is out of the question, as there's no room for one (the current one is build into the room).
I tend to sit with my legs criss crossed but with my right leg on top of the left (so they are not crossed really) and they go under the desk or I put them on the top of the desk and scooch forward so my knees are touching the top of my chest.
Dunno why but its comfortable and no pain lol, I actually start to ache alittle if I sit in the "proper way" for a long period.
Can sit like that for hours with no issues....
I Dunno why but its comfortable and no pain lol, I actually start to ache alittle if I sit in the "proper way" for a long period.
Basically your muscles/ligaments etc are used to that position, sitting "correctly" is stretching them into a place they don't often go. Comfortable doesn't necessarily mean good for you.
Then i dont know, put something under the chair?
Sit on a pillow?
DIY on the desk?
Just how high is the top from the floor?
Tried sitting on a pillow - annoyingly the arm rests are too low down, and it didn't elevate me quite enough.
Looking at the desk, it didn't seem that high. Perhaps the height of my chair isn't great
It might be desk posture that's behind the issue.
But it can most likely be fixed, concentrate on fixing the issue rather than worry too much about desk posture. Google wrist/forearm pain exercises.
When at a desk I always used to keep my wallet in my back pocket but recently saw this on Reddit and stopped.
It might be relevant to this thread? :confused:
A cheap thing to try would be support for your mouse wrist. I use a small bean bag. It's a flat floppy tube, sold as a neck support for sleeping in a chair IIRC, but whatever works. So my mouse arm is supported at the correct height at wrist (by the desk and the bean bag on it) and elbow (by the arm of my chair) and there isn't any significant pressure on my wrist (which is very important because it's vulnerable) or elbow. All my mouse use is just wrist and fingers and not much of that. I'm fine using a mouse for hours on end day after day and have been for years. No strain at all.
A console controller, on the other hand, wrecks my hand. A couple of hours of that and my thumb is painful for days. It's why I'll probably never switch to console gaming despite Microsoft's malware and the increasingly farcical cost of PC hardware and the poor PC support (proper PC support, not a quick console port) from game devs.
Given the pain you describe, medical advice might be a good idea. If it's that bad, something is wrong and reducing the cause of the problem might not be enough.
My girlfriend made me a mouse and keyboard rest for Christmas - I don't find it helps much for me :(
I need a chair that stays up a bit higher - with my proportions I have to use a desk that is right at the top of the recommended height and the gas lift on most chairs settle a little after being set resulting in bad posture and my shoulders and neck being scrunched up if I don't keep thinking to reset my position :(
