- 14 Jul 2013
- UK
Ok guys thanks for the replies. Ive ordered some liquid metal, it should turn up wed/thurs. So i'll report back my findings and see what happens!
While Conductonaut will improve temps a couple maybe 3c, it does not change temps as much as yuo are seeing. Something else was not right in earlier install.
orbitalwalsh explains it correctly plus there is one more thing that make the conductonaut becomes super effective compared to to regular good tim in such case, that is because the gap between the IHS and the CPU core is incredibly close after you clean up all the black glue and with the mounting pressure "big" particles of regular tim will be push out or do not fill the micro gaps very well, on the other hand, conductonaut is made from mixing indium, gallium, tin, etc... which have significant smaller sized particles thus filling the micro gaps between the ihs and the actual core much more effective and due to this the heat transfer rate is superior compared to normal tim.I'm glad you now have good heat transfer and great temps, but the reality is metal TIM is only 2-3c better than good name-brand normal TIM.
Here is link to testing of 85 TIMs including one you are using. There are 14 TIMs within 2c and 39 within 3c. Even using denture cream their temps were only 8c warmer than Conductonaut.
https://www.tomshardware.co.uk/thermal-paste-comparison,review-33969-8.html
kryonauts 12.5 W/mk vs conductonaut 73 W/mk ... no brainer their
reason why we use kryonaut on the IHS bar from it avoid nightmare mounting issues with liquid metal is that there is a large surface area to spread the heat , so even if per mm2 there is less conductive material, there is still a lot of space to dissipate the heat.
from die to IHS, the die is such a small area you need the highest possible conductive material to get that heat out onto the IHS
also wonder what the degradation period would be on the paste on direct die heat . Intels own i poor but designed to last
I have tried it myself several times and found similar results as the original poster.
The test you link is legit in relative to normal operation however it does not show to true potential of liquid metal based tims, these special tims works best only when the gap of the two surfaces becomes very very very close and the surfaces must be mirror-like finished (like the surface of the CPU cores when you clean up all the residuals). Then and only then it distances itself from regular tims.
Yeah, elephants and pigs fly too.
I don't care how many times you re-did TIM on chip and iHS, you was not done correctly until this last time. It it had been done correctly your previous temps would have been about 2-3c warmer than they are not with Conductonaut .. 4-5c improvement is be a real stretch even with Conductonaut on both CPU and IHS.
My guess is you finally got all the caulk/glue off of IHS and CPU PCB so edges of IHS were flat with IHS over CPU chip, so instead of a layer of TIM between CPU chip and IHS compounded by another layer of TIM between IHS and cooler base you finally got direct silcon to metal with TIM filling void on chip to IHS and metal to metal with TIM filling voids between IHS and cooler.![]()
doyll, have you ever experimenting with conductonaut/liquid metal versus regular kryonaut tim between IHS and CPU core? I have and weirdly my results are very similar with C6ckneyGee3zer's.
I have tried a considered number of times not only on my 8700Ks but at least a dozen 6700K/7700K in the past and found similar results.
I was trying to build a pre-overclocked for my long distance relationship gf, my intention was trying to provide a decently high clocked cpu (4.6Ghz quad core) with minimal maintenance since we could only meet once or twice a year hence my idea was deliding the cpu, then use regular tim like Kryonaut to replace the Intel stock tim since it is less risky compared to liquid metal. However, when I actually tried it I found it was still very hot (above 80) during load which made overclocking seems impossible, no matter how many times I tried to re-seat and re-paste it, the temp did not seem to get anywhere close to liquid metal. This somewhat verifies or at least gives one more similar result with what C6ckneyGee3zer has found with his CPU.
I can understand 10c or better for pre-delidding to delidded. What I cannot understand is how simply changing pasts on an already delidded system because TIM does not make that great a difference. Delidding's biggest improvement is not better TIM but removing the space between CPU chip and IHS so there is direct contact between them instead of a layer of TIM. 10c is the kinds of difference seen between something like toothpaste and liquid metal TIM with direct contact between surfaces, or TIM between not contacting surfaces, not good TIM and liquid mental with direct contact between surfaces.
I dropped about 10 degrees delidding with normal tim,then another 8-10 using LM.
Good job.
