- 27 Apr 2007
1. Does the AM4 Ryzen platform support half multipliers?
2. Is BCLK over-clocking possible and to what extent?
3. With an unlocked multiplier increasing BCLK can’t offer much in terms of higher CPU clock speeds that can’t be done with a higher multi but would raising it improve performance of any other aspect of the system?
4. Are all the frequency domains independent or would raising BCLK automatically raise other system clocks? Or are there ratios to play with?
As you can see I’ve never used a Ryzen system so have no idea of the inner workings. Thanks.
