8700k delid made no difference at all?
I can assure you all the glue etc was off cleaned off properly. Everything was seated correctly. After re trying everything again 4-5 times with the same results...then I try Conductonaut and it works as it should..must be conductonaut.
It's strange though as my delid results with my old 3770k were great, I lost 20*c when using Kryonaut. Maybe Intel having made their paste better since then? As there is not much difference between stock and aftermarket poaste on a delid it seems on modern CPU's?
Apparently, it seems that Intel does indeed use a better tim for coffee lake compared to previous gens.
Found this video from Der8auer in which he mentions about it at around 1:45
@doyll
