Phantek RGB Adapter Does Not Fit Gigabyte Motherboard?
27 Apr 2018
Hey all,
I have purchased the following adaptor to use with my Phantek Halos.
https://www.overclockers.co.uk/phan...xNtzCwm7grgjspBxU9iy1FKdlRW47axEaAn6lEALw_wcB
On Phanteks website here it claims compatabillity with "Gigabyte RGB Fusion"
http://phanteks.com/PH-CB_RGB4P.html
My motherboard is a Gigabyte 270X Ultra with a 5 pin RGB header.
The issue is that when I go to plug in the phantek header it is physically too big to plug in to the 4 pins with out bending the 5th.
Is this a common issue or am I missing something? All gigabyte boards will have the same 5 pin header, so is this just not compatible or are we expected to bend the 5th pin?
Thanks
13 Jul 2009
Llanelli
Sounds a bit odd to design something where you need to bend the pin in some cases.
The 5 pin headers also have a W channel, I expect for a RGBW system rather than plain old boring RGB.
The Phanteks seems to be designed around a locking connector and not just a pin header that Gigabyte has.
24 May 2006
Surrey - UK
If you click the compatibility section on the Phanteks product page, whilst they do show a Gigabyte Fusion logo(perhaps in error), it does not list any Gigabyte motherboards. I'd be inclined to email Phanteks and ask them directly and specifically.
OP
27 Apr 2018
I have sent them an email but have not heard anything back as of yet. They only list 3 or 4 motherboards on their list, no way that can be conclusive surely.
24 May 2006
Surrey - UK
Maybe not, but better to get a definitive answer than chancing it. If the pins aren't lining up nicely, i'd not risk my hardcore forcibly testing it.
1 Dec 2015
4 female from phanteks to 5 male pins on ggabayte board. You just got to leave the 5th pin not plugged in and you get this
Only the digital ones isn't supported and you need xspc switch cable to get it to work
OP
27 Apr 2018
snip
Thanks, So I have the same header in the same place on my motherboard. But it will not physically press down as when it is lined up with the 4 pins, it catches the 5th as the head is too wide so it can not go down. Yet the header will be the exact same size as your Aorus board, wtf
1 Dec 2015
yeah 5th pin get moved/bent a bit . Used that phanteks connection which is slim! and other hard female socks which pretty much bends the 5th pin!
whats annoying is I ALWAYS plug the wrong 4 pins in haha
FYI- if anyone want to use the Digital Halo with Aorus boards.. need this - crossed over the 3 lanes to the standard layout other vendors and products use
https://www.overclockers.co.uk/xspc-3-pin-gigabyte-rgb-30cm-extension-cable-wc-468-xs.html
OP
27 Apr 2018
Ah so it is normal for the 5th pin to get bent/moved while using the phantek then. Am I understanding correctly?
OP
27 Apr 2018
So I have now heard back from phantek. After showing them pictures of the issue they have stated that the older style cable will fit. They have offered to send me one out for free, so when this arrives will update and confirm if it is a better fit.
Thanks all
1 Dec 2015
Thanks all
ah didn't realise they changed the style of it ?
