So, I got a new system for work, went for R5 1600.
Started overclocking it (course I did). And found that while 3900Mhz is rock stable at 1.4v (yet to try and bring this down but temps are fine.) but at 4000Mhz - 1.4v it wont even boot. Like, I don't mean windows, I mean cant even get into the BIOS!
Now, fair enough, 3.9Ghz is my limit. I have no issue with that. But just find it odd it's such a difference in behaviour at 100Mhz increase. I'm used to with Intel, if something is rock solid at 3.9Ghz then I would expect it to maybe fail after some stress testing 100Mhz higher, add another 100Mhz and you might not get into windows, add another and it might not boot.
Not complaining, just surprised in the start difference between rock solid and wont even post at 100Mhz increase.
