PLAYERUNKNOWN'S BATTLEGROUNDS - Thread
The netcode is broken, worse than blacks ops and for a FPS the net-code is the bread and butter of the game.
Playing on the NA servers at least gives you half a chance.
Weird game just now, went myalta (long glide), got average loot, found an unopened crate on the way to the circle.
Contained full lvl 3 gear, a groza and silencer and ammo, then locky and jarakin got killed by a blue rider just inside the zone, managed to get him as I had stopped to first aid to get into the zone.
Pushed on, locky and jarakin spectator spotted a guy trying to snipe me, got ready to have a peek and....
STEAM DISCONNECTED.
Game closes, can't reconnect, locky is sat spectating me get to 5th while AFK with probably the best gear ive ever had in a game, still never got to fire the groza in anger :(
shotguns are amazing now. me locky been using them.i often pick a pumpshotty now for close up now when fancy a change from the ump.
So they have basically put them back to how they were before they ***ed about with them and ***ed them up. Great development work there. gg
M24 now spawning the world instead of care packages, probably a good choice as I never saw it as being better than the Kar98k anyway.
Always suck with the Vectors, what makes them so good?
It's always been a monster close range due to the DPS it can put out, and with the recent SMG buffs, it’s even more viable mid range. I’m also pretty sure SMG’s have a faster movement speed than AR’s too.
So at close-mid range, you’ve basically got Groza level damage, with faster movement/reload/ADS/hip-fire than an AR, with ammo that is pretty easy to find. Plus, the suppressor is great fit as you don’t need to worry about recoil as much, and it’s quieter than an AR.
Disclaimer: For more than 2 targets, per mag, it’s not ideal and you definitely need an extended mag.
SMG Patch Notes
  • Increased limb shots modifier (it’s now 120%)
  • Slightly increased the damage of the Micro UZI, UMP9, and Vector
  • Decreased vertical recoil on all SMGs
  • Decreased recoil and scope sway when moving in ADS (aiming down sights)
  • Increased ADS transition speed
Don't like M24, was in top10 yesterday and headshotted a guy about 20 metres in front of me behind a tree and he lived. Turns out he had a L3 helmet which left him with 1 hp. Rushed him with my AK that I'd apparently forgot to reload so he kill me. All this is M24s fault, not my own incompetence ;).
Yeah, I've noticed this. I got two headshot knocks on Erangel the other day in Rozhok and just by firing it through the window. Could have both been miracle shots but they definitely seemed to have stealthily upped the damage on them.
I prefer the M24, at least its not some relic left over from the 1930s.
Still would drop both if a SLR or SKS came my way.
Been playing with the VSS when i can find one, its a beast at < 150 and with the extended mag is way better than any SMG.
Right, time to join/try the crew. Me and friend only really play duo together but fancy joining the OcUK crew.
Thought I saw a previous post mention Discord info in the OP but nout there.
