- 27 Apr 2011
- UK
anyone managed to get onto the test server? Just gets stuck at matchmaking for me
Looks like we (almost) 60hz tick now boys
Total and typical muck up by BH in their recent update. Appears that many people can't play due to Battleye errors (me included). Anyone on here having problems?
So they have basically put them back to how they were before they ***ed about with them and ***ed them up. Great development work there. gg
This is a big improvement if it translates to the live environment correctly. Although one packet doesn't necessarily equate to one tick/update? Large amounts of data in a single 'update' might be split across multiple packets, so 2 packets becomes 30hz and 4 packets 15hz and so on.
My only worry is that Bluehole's infrastructure already struggles with the current volume of traffic, increasing it is only going to cause more congestion and performance problems. Hopefully with all the loot crate money they actually invested in infrastructure with more resources and increased throughput.
It is Bluehole after all![]()
They're infrastructure shouldn't be a problem here. It's running on Microsoft Azure's platform, which is hugely scalable, almost as good as AWS, as long as they are using the correct instance sizes for their servers. It would be interesting to see their monitoring reports of how they seem to be running!
PC still uses AWS, Xbox uses Azure.
Finally found a bit of a groove, had some decent results and ended up 1800+ which im happy with.
Need to start using peek more, what key bindings do people use to make this easier, Q and E seem so alien to use or are you mapping them to mouse buttons?
I use those defaults but set to toggle rather than hold which I know is not good but I find it weird using hold and then trying to use a and d to eek further left or right as necessary to peek around something when I am not quite in the right position.
If you’ve got side buttons on your mouse then you can switch peek to those. I find that much better.
how do i join the discord team would be good to play with more experienced people.Since joining the discord channel I rarely play Solo unless no one around or for a quick warm up whilst folks are mid game. Much more fun and you learn a lot.
