Lets guess the spec of the 1180
Man of Honour
21 May 2012
Dalek flagship
For fun lets see how close we can guess the spec of the next gen NVidia card (The 1180)
If you want to have a go please fill out the following specs.
Clock Speeds
GPU Clock -
Boost Clock -
Memory Clock -
Memory
Memory Size -
Memory Type -
Memory Bus -
Render Config
Shading Units -
TMUs -
ROPs -
SM Count -
Board Design
TDP -
Here is my guess
Clock Speeds
GPU Clock - 1500mhz
Boost Clock - 1700mhz
Memory Clock - 3200mhz
Memory
Memory Size - 12288MB
Memory Type - GDDR6
Memory Bus - 384 bit
Render Config
Shading Units - 3840
TMUs - 240
ROPs - 96
SM Count - 60
Board Design
TDP - 200W
Clock Speeds
GPU Clock - 3500MHz
Boost Clock - 4000MHz
Memory Clock - 6500MHZ
Memory
Memory Size - 24.5GB
Memory Type - GDDR6X
Memory Bus - 1024Bit / 34Bit
Render Config
Shading Units - 5000
TMUs - 1550
ROPs - 550
SM Count - 5000
Board Design
TDP - 600W
Clock Speeds
GPU Clock - 3500MHz
Memory
Render Config
TMUs - 1550
ROPs - 550
SM Count - 5000
Board Design
TDP - 600W
Is this on the new Asimov architecture.:)
Clock Speeds
GPU Clock - Irrelavent. It's always boost. Look at my hand, it says boost. What's the name of the juice bar around the corner? It's Boost. Look at your watch, yep its bloody boost-o'çlock. Lets go.
Boost Clock - 1.21 jiggahertz
Memory Clock - 4Hz
Memory
Memory Size - What memory shortage?
Memory Type - Quintuple data rate
Memory Bus - Stagecoach No 10
Render Config
Shading Units - 0118 999 881 999 119 725 3
TMUs - Andy
ROPs - 48, no 64, actually don't worry your pretty little head about it
SM Count - Yes
Board Design
TDP - 250W
Clock Speeds
GPU Clock - 1600mhz
Boost Clock - 1750mhz
Memory Clock - 4000mhz (16Gbps)
Memory
Memory Size - 8 & 16 GByte
Memory Type - GDDR6
Memory Bus - 256 Bit
Render Config
Shading Units - 3584
TMUs - 224
ROPs -64
SM Count - 28
+ Tensor Cores
Board Design
TDP - 180 W
Clock Speeds
GPU Clock -Drip
Boost Clock -Drip
Memory Clock -Drip
Memory
Memory Size -Drip
Memory Type -Drip
Memory Bus -Drip
Render Config
Shading Units -Drip
TMUs -Drip
ROPs -Drip
SM Count -Drip
Board Design
TDP -Drip
Price- Rape
Clock Speeds
GPU Clock - 13:14
Boost Clock - 13:15
Memory Clock - I forget
Memory
Memory Size - 256K
Memory Type - forgot
Memory Bus - Double Decker
Render Config
Shading Units - Trees
TMUs - No idea what that is
ROPs - Skipping ropes?
S&M Count - Oooo Arfur
Board Design
TDP - Big enough to fit in a case and will use the power of a lemon
With current 1080 ti prices they cant leap too far ahead with the specs as the price will put the average buyer off.
10 - 15% performance over the 1080 ti sounds plausible.
I would assume that once the 1180 is out 1080Ti will end up like the 980Ti did, get a nice discount, be cleared out and 1180 will be the new king. Been like this for a long time now, unless something changes I am confused why every time a new gen is coming out people come out with the same comment.
I remember when the 10 series was coming out lots of people would say it cannot be faster and cheaper. If it is faster it will cost more yada yada. If it was like this graphics cards would cost more than a house by now.
