Man of Honour
- 21 Nov 2004
Dusty car, too hot too wash!
Can anyone recommend a good car vacuum cleaner? Something with a crevis tool / end for getting down the side of the seats? I bought a car vacuum from Argos but it had no suction so I took it back.
Bilt Hamber Cleanser Polish.
I bought a used approved BMW about a week ago.II have just ordered a whole bunch of cleaning stuff; shampoo, super resin polish, aqua wax, extra gloss protection etc
I was wondering how far I should go with my first clean? I know the dealership had done some polishing as some light scratches were removed. Would an clean and an aqua wax be sufficient?
My kid's just bought a Honda Jazz, solid red of course so the colour is a bit faded in places. Will it need a DA polish to bring it back to life or can it be done by hand?
Bit worried as the paint is apparently quite thin/soft on Hondas.
Estoril BlueDepends how far you want to go. Not having known how it's been looked after before I'd be very tempted to go all the way so you can carry out a proper assessment of the paint and whether or not it needs a polish/correction.
What colour is it btw? I want to say grey from some of your other posts but can't remember!
I want the bugger looking like a mirror and then having the glass coating applied to provide a bit of protection. I know it's not magic and things will still go wrong but I'd rather have a layer or two of ceramic to take the brunt of a stone chip or daily use scratch/mark than bare clearcoat and very revealing black paint. Plus the ideal of having a silky finish a quick maintenance snow foam wash and dry will preserve rather than the current situation of bare clearcoat attracting dust and fallout and waterspots and turning matte minutes after drying.Likewise, I have an 07 Honda Civic Type R and the paint hasn't been brilliantly looked after by the previous owner so has plenty of micro-swirling.
My cleaning routine has never included anything more than snow-foaming and leaving it for 5-10mins, washing off, then using a wash+wax on the car with a mitt.
What should I be doing?![]()
