due to the no hyperthreading in the near future (say 2-3 years) I think it'll be hitting 100% usage like 4 cores are nowwhy not an i5-8600K as that closer in price to a Ryzen 1800x (there only about £5 to £10 difference)
The 8400 by is far the best gaming cpu for the money they have been going as little as £120 recently and don't need good ram or cooling or motherboard to get the most out of them.
Review here
https://www.pcgamer.com/intel-i5-8400-review-the-best-new-gaming-cpu-in-years/
Do you do anything else with your PC? Both chips are overkill for gaming, even paired with a TitanX or a TitanV
I'm afraid not for gaming, well according to the article you just linked to...
But when it comes to games the Core i5-8400 simply gets it done with less fuss. To replicate the performance seen in this article you merely need a basic B360 board, some low latency DDR4-2666 memory, and well... a GTX 1080 Ti, but you get the point. It’s also possible to squeeze another 5-10% out of the 8400 by using a Z370 motherboard and DDR4-3200 memory, though those gains are only realized with a high-end graphics card.
LoL
The ryzen setup is DOUBLE the price.
I have no axe to grind with you, though on this point you are clearly wrong.For a start if you use a B360 board you cannot overclock the memory, if you use a Z370 board its much more expensive and the 8400 is not overclockable at all.
by comparison an £85 B350 on the Ryzen will overclock the 2600 and the memory.
The stock out of the box Ryzen 5 2600 performance can be achieved for roughly the same price as the budget Core i5-8400 build, and given the Intel CPU was faster overall this makes it the better value choice for gamers.
1. Imginy said "The 8400 is by far the best gaming cpu for the money..."
2. You reply, "Old review, 2600 is now best." and then link to the TechSpot review
3. The Techspot review more or less backs up what Imginy original stated. It definitely does not state that the "2600 is now best"
Here is another quote from the Techspot review you linked:
I often agree with some of the things you say humbug but on this point you are unequivocally wrong. In my experience it tends to show maturity and unbiased reasoning when somebody actually admits they might be mistaken, rather than jump from point to point in an effort to obfuscate their earlier error.
Just curious but why did they not use the same speed ram on the Intel chip as they did on the AMD ? Having memory that's nearly a whole GHz faster doesn't exactly make the tests even.
LOL as if that test is fair
Look at the price of that overclocked Ryzen setup that motherboard alone must cost around £250 compared to about £85 for the B360 motherboard they used with the intel setup
OP,OcUK are doing a Ryzen 5 2600 bundle with a free SSD,which is worth considering IMHO:
https://www.overclockers.co.uk/amd-...-team-group-ram-free-240gb-ssd-bu-01f-am.html
You are saving nearly £50 buying the bundle instead of buying the separate parts.
Edit!!
OFC,it might be useful to know what games the OP wants to play too.
That whole system, X370 Gigabyte board, 240GB SSD, 16GB 3000Mhz Ram and the 2600 is £435, the 8700K on its own is currently £360.
Common guys.... if you're on a budget and looking for a full system it doesn't get any better than that, unless you're budget for those components is £300 or less, in which case good luck finding anything let alone anything of that quality, that is a great system.
Why?
They don't give you 8GB extra RAM for free...........................
