- 15 Nov 2008
- Reading
So yesterday I hit a fairly hefty pothole in Wales and after having a look for any damage, there was a massive egg shaped bulge in the sidewall. Didn't feel like risking the 110 mile drive home so thought I'd put the spare on and sort the tyre out later.
Tried to undo the bolts and all that happened was the wheel wrench bent (thanks Peugeot!). So had no choice but to use my breakdown cover to change it, who are Start Rescue.
First guy turns up, undoes the 3 non-locking bolts, commenting "I thought you said they were tight", and then on the locking wheel bolt happens to shear the head clean off the bolt with barely any pressure. Great.
He then left and another guy turned up to transport the car back home, where it's now sat.
I did a bit of research and apparently the bolts are designed to shear when the wrong locking socket is used, or if the socket isn't in the right orientation (which I'm pretty sure is what's happened here).
Now I thought I would easily be able to claim the cost of getting this fixed back from Start Rescue, but on reading the terms it says they aren't liable for any damage caused by the recovery operator.
Does anyone have experience in claiming for anything like this?
Secondly, both fronts were Michelin PS4's with about 3.5-4mm of tread. I obviously need at least one new one, but would you replace both fronts at the same time? The difference in tread depth is making me a bit cautious, but is it something to worry about?
as I only really know the peugeot 205 1.9 gti from the late 80's.....
