Yea put me down! Either lexus or mx5.
Mx5 is a bit unwell right now so depending if I manage to fix it soon or not!
Whats up with it? lol
Slave is normally it falling flat on the floor isn't it? Good idea to replace both though!Clutch slave or master gave up today! Not sure which but I'm leaning towards master as it's very weird behaviour! Will replace both just to be safe as they're both cheapish all in. Slave is not leaking and neither is master but pedal is soft as hell and it work go in gear at random, worked fine at first and then stalled twice with clutch fully in! Old cars![]()
It's a very common problem on mx5s.. but slave usually leaks fluid with clutch still feeling ok, unless it full on pees fluid out. Mine has 0 leaks but they're like £18 part and if I'm swapping master and bleeding the system I might as well get it in! It was failing and stalling today but then drove fine ?! Weird to say the least but I don't want it to fully crap out miles away from home heh.Slave is normally it falling flat on the floor isn't it? Good idea to replace both though!
Hello! I am notoriously unreliable when it comes to these meets, often unable to commit until the last moment. So I would say just pick any date and structure, and I will do my best to attend - I don't want to vote for a specific date and then not be able to make it. Same goes for the structure, I'm mainly in it for the drive, so either way works for me![]()
I have! Check the OP.
I live just round the corner from The Woodman, not got a flashy car though.![]()
and the food!Damn right. Went to one in my Polo before as well.
Both times were just as fun as if I had brought something exotic. The wobbly Skoda provided much amusement for people, and it was great fun ragging my poor little Polo trying to keep up with everyone.
Still worth it for the drive and the people.
Ah yes and that too.and the food!
