Rounding all this up in one place for new TV & GPU buyers. It's amazing how confused people are across the web at the moment concerning refresh rates and GPU compatibility:
Hope that helps clarify what you need to game on a 4k TV without screen tearing, regardless how good the next gen of GPU's perform. Could be a big swing factor for AMD?
			- HDMI 2.1 is the future new connection standard for 4K TV's that allows Variable Refresh Rate (VRR) - TV's with full HDMI 2.1 are expected to release anywhere between now and 2020!
 - HDMI 2.0 TV's that are already out now can actually add VRR support to their sets with a software update. (Samsung are doing this for some sets already)
 - HDMI cables - [EDIT] Your common 'High Speed' HDMI cable should allow 4k @ 60hz, but any higher you actually need to buy a new higher bandwidth cable (max 120hz) called 'Ultra High Speed' or '48G Cable'. [DOUBLE EDIT] I can get 4k @ 60hz on a ~1 meter long cable, but not on a 3 meter long cable. All sorts of GPU and Display errors happen on the longer length cable.
 - FreeSync is just AMD's name for VRR essentially as it's the same refresh rate standard underneath. AMD's latest GPU's and CPUs will give you VRR gameplay on an HDMI 2.1/2.0 VRR enabled 4K TV.
 - VRR as a TV standard is also going to be supported by AMD GPUs alongside its own FreeSync (the set may say its VRR, not specifically FreeSync, but it should still work)
 - G-SYNC is nVidia capitalising on their dominant market position to lock their customers into their own proprietary hardware ecosystem. G-SYNC is a competitor to VRR and is unlikely to appear in 4k TVs. GeForce GPUs currently don't support HDMI 2.0/2.1 VRR - but that could change in the future...
 - 4K VRR - Well, HDMI 2.0 VRR will get you a 4K resolution at 48-60hz VRR. Pretty slim window really, would like to see a demo of that. It will do 1080p between 20-120hz however, if the TV is a 120hz native panel.
 - DisplayPort. 4k TVs dont have 'em!
