- 27 Jul 2006
- Huddersfield
The following build is something im putting together if something goes wrong with my overclock of an old system.
Ive not used a watercooler before, and to be honest the very idea of them worries me a bit - what happens if they leak?
But ive been told they offer a nice neat and often quiet solution to cooling a CPU.
I would appreciate if you could look at this below and let me know for around the £70 mark would an AIO Water cooler be better than an air cooler. What cooler you would recommend for stock speeds and maybe overclocking it bit ( im pretty sure that b360 allows it otherwise ill have to change it).
Ideally id like it to fit in with the whole red/black aesthetic going on inside.
CPU: Intel - Core i5-8600K 3.6GHz 6-Core Processor
Motherboard: MSI - B360 GAMING PLUS ATX LGA1151 Motherboard
Memory: Corsair - Vengeance LED 16GB (2 x 8GB) DDR4-3000 Memory
Video Card: KFA2 - GeForce GTX 1070 8GB EX Video Card
Case: Phanteks - Enthoo Pro M ATX Mid Tower Case Power Supply: Corsair - TXM Gold 650W 80+ Gold Certified Semi-Modular ATX Power Supply
Thanks again for your help
