- 28 Dec 2017
- Beds
Nowhere near a rice grain, a pin head! Probably less than a 1mm sphere. And the same amount on the IHS.With regards to application of conductonaut it really needs as little as possible. rice grain or smaller and manually spread over the entire die.
Very true about idle temps though, they're fairly irrelevant so long as they're not obviously showing up a bad cooler mount.
