Time to get the room ready.
A bit of plumbing
The joists were so bad, that I had to plane a joist down with pipes running along it. Solution... cut the pipes, plane joist, redo pipes. I also added in a new flow/return to add a radiator in the kitchen at a later date (capped with push fit end stops - these things are great)
@CrispyWombat I hope you're prouder of this plumbing attempt!
Preparing the ceiling
Next onto preparing the ceiling for plasterboard, and my favourite method I've invented (I think - Probably not) for levelling the ceiling!
Some final wiring tidying up
Boarding
Kitchen first fix wiring
We've got a single oven / combi and combination gas/induction hob so needed to get that done and wired in
Next day, plasterers are coming in to plaster the entire house pretty much
A bit of plumbing
Boarding
