I took the gpu block off when i was adding the LEDS and now temps are 45 on the gpu with the fans at 600rpm, not sure if it was tightened down too hard or what but this is more like the temps i was expecting.
I can keep the gpu at around 40 if i run the fans at 1300rpm.
I noticed with watercooling that the CPU temps for example a Noctua D15 is not much worse. For example if you had 4 x 480mm radiators would the CPU temps be similar to GPU temps? Or are the CPU temps always 60-70c even if you had any amount of radiators?
