I7 8700K Running hot... or is it?
Caporegime
18 Oct 2002
Ireland
I just don't get why Intel do this, I mean what does it take for them to apply decent paste?
They claim they use TIM because solder can crack after a while, its also much cheaper to use TIM. I think the last chips they used solder on was sandy bridge and broadwell, and i don't see masses of posts with people saying those chips have died.
23 Jun 2018
Leicester
Yeah, I'll just go for delided chips in the future, would have been better for intel to use liquid metal and add a bit extra to the cost but then again OCUK do this, lesson learnt.
12 Jan 2017
Its pathetic, they just dollop this stuff on and hope for the best. You can see most of the core was barely touched at all, at best it was fractionally touching which obviously would do almost bugger all to transfer the heat to the ihs.
If intel are too cheap to use solder (despite their hurr durr bs of it cracking) then why not the liquid metal route? Or would that take too long for them to do properly?
no, the core was covered fine, problem was that the thickness and thermal conductivity level of the paste. You can see the paste of part where the core "barely touched" stick to the IHS instead, this is pretty common when you take them apart.
Caporegime
18 Oct 2002
Ireland
But you would still see a pretty decent imprint on the actual die, there's quite substantial parts of the die that are quite clearly totally clean of any type of thermal compound. If it was touching properly it would have made a mark at least. It's like they put this stuff on in small rectangular clumps and they're not all even so 1 end can be higher than the other which causes issues in regards to it touching the actual die.
That's my take on it anyway, if intel are so concerned with "cracks" in the solder (cough penny pinching) then surely liquid metal is a far better alternative (and presumably cheaper than the solder setup) than this crap they're using? Then again liquid metal just can't be globbed on as easily as TIM can so i doubt they would go that route.
13 Jun 2009
Intel's main argument is that dies are smaller these days and that can cause issues with solder that didn't materialise with Sandy Bridge, etc. It's a fair enough argument (although AMD doesn't seem to agree since they continue to use solder), but it's still no excuse for terrible application of TIM.
Caporegime
18 Oct 2002
Ireland
If that's intels stance then why do they insist on using TIM which seems to crank temps up by around 15c or so compared to liquid metal? Its pretty obvious the TIM isn't doing a good job . They can glob on the TIM easily while liquid metal requires careful application, just seems to be a quicker and cheaper method rather than them doing it right.
28 Dec 2017
Beds
I don't understand the people suggesting liquid metal in stock Intel CPUs. Their TIM situation sucks but liquid metal in millions of consumer products is a TERRIBLE idea. It's just too risky when it will go through postage, etc.
They need their chips to last a safe minimum of years and ideally a decade when taken care of, regardless of warranty. You wouldn't buy a product that literally was guaranteed to fail after two years and one day. Liquid metal simply isn't a proven ten-year solution. Crappy TIM is doing the job just well enough to let them keep selling the chips.
Caporegime
18 Oct 2002
Ireland
You honestly think that there's not a way they could engineer the ihs so they could keep the liquid metal centered on the core? If they're not gonna to do it properly with solder then liquid metal is an alternative that doesn't have all these OTT intel dramatisations of cracks possibly appearing. The thermal material they're using simply isn't up to the job. It would be one thing if it was only a few c difference, but we're talking 15-20c difference in some cases.
They obviously wouldn't even consider liquid metal as it requires far more careful application than the crap they currently use which seems to be slung at the core from several feet away.
28 Dec 2017
Beds
I just think that their method of throwing crappy TIM from several feet away is producing chips that rarely fail, they just run hot. But the vast majority of Intel customers aren't even checking temperatures, and certainly not relying on low ones being available. Even lots of people who buy K-series CPUs end up never overclocking them.
Basically it's working for Intel to do a pretty bad job but a consistent one. Maybe it's enabled by their complacency due to market leadership, and will change. I'm still getting used to the fact Intel's chips are considered the burn risks and AMD are the ones staying cool, after the entire FX era CPUs and GPUs.
13 Jun 2009
Liquid metal isn't required on a consumer product but certainly they could put more effort into using better TIM and applying it better.
22 Nov 2009
Under the hot sun.
Probably down to the crap TIM they use, when i delidded my 6700k last year the application was pathetic.
Barely any real coverage on most of the core and a thick coverage on a few small parts of it.
My 8600K had less paste, you should feel better :p
And wasn't there some videos last year showing that some have good paste amount others bordering to almost nothing?
22 Nov 2009
Under the hot sun.
Yet they are using it on Skylake-X, and especially the 7900+ are pretty huge silicons. The 7980XE takes almost the whole package. One of the biggest silicon blocks the consumer systems ever had.
Intel are just money pinching. 4820K was soldered, a small chip, was run cool and was overclocking pretty high. It's sibling the 4770K was boiling water even at stock speeds. Same chip sizes. Didn't see the 4820K cracking.. :D
13 Jun 2009
I completely agree they are penny pinching. Even if their argument has some merit, their actions don't add up and they are clearly just trying to save money for some reason.
Caporegime
18 Oct 2002
Ireland
Same situation with gpu's in regards to paste but at least those are relatively easy to replace without the oem being any the wiser.
19 Feb 2007
ArcCorp
It's not actually the TIM they use that is the reason for the temps, The TIM is designed for very long term use, The reason for the bad temps is the amount of silicon they use to attach the IHS which leaves a sizeable gap between the die and the IHS.
Permabanned
1 Jun 2004
London
They should solder the K series chips and charge us for it. As for the rest of them, what's the point, they're not overclocked. It's us that run them over specification and therefore benefit from additional cooling. Look at the standard heatsinks they provide, it all works as it should.
