Cap to close off washing machine valve
Caporegime
13 Jan 2010
Llaneirwg
I need to cap this connection
But I don't know what to buy or search for to do it.
I'm guessing someone here knows?
What I believe you're looking for is a called a blank nut. Have a look on screwfix/toolstation, or even better, get down to a store with the part in your hand to make sure it fits exactly.
Thanks guys! Much appreciated!
Got one of those 3/4 blank nuts from screw fix
Which was still open!
Didn't have any ptfe tape so just tightened it hard as I could. All sorted!
Did it come with a sealing washer? If it didn’t, and you didn’t tape it, it’s unlikely to be properly water tight.
Had a little rubber washer in the bottom. But it really needed my full force to get it to work.
You should be sorted then. Easy enough to test, open the taps and see if anything leaks.
Came back to house today (accidently left water on overnight). No issues. Thanks guys, I had to explain to the guy at screwfix exactly what I wanted as he didn't know!
