- 20 Dec 2013
- West Sussex
Hi there
I've just built a newpc, i originally did a test boot and it worked and showed the BIOS so i proceeded to install the components into the case. Once it was in the case i added a 120mm AIO CPU cooler which also runs as the lights are on and can hear the pump and has been installed correctly and a HDD, everything else was test booted. I know that the HDD works as it was from my previous build.
Components are:
AMD Ryzen 2600x
MSI B350M Gaming Pro
G Skill V Series DDR4 8GB
MSI GTX 1080 Gaming X
EVGA G650
It all turns on in the case and all the lights come on for the specific components but the 'EZ DEBUG LEDS' are showing that the CPU & RAM are either not detected or failed according to the manual but surely this cannot be the case if it has already posted?
Picture for reference: https://i.imgur.com/RG7VrfU.jpg
Thank you some help would be greatly appreciated
Components are:
AMD Ryzen 2600x
EVGA G650
