- 6 Sep 2016
Try a few other brands..
I'd definitely add a Poweramp for that Sony avr
Thank you for that explanation that makes perfect sense.
So I guess to power bigger speakers one needs another amp...what would you recommend?
ROTEL sound great when paired with B&W speakers. I got myself a used RA-1080 and it drives my CM9's very well. Very clean, and precise sound with plenty of bass if needed via the contour switch.
Sounds like overkill for the speakers OP is looking at... a £500 AVR to power £1000 speakers is perfectly good enough...
The speakers are rated at 25-200W at 8 ohms
Doesn't mean much what is impedance sweep they could reach down to 4ohm
If you have a avr then you want to use a power amplifier not a stereo integrated amp. Ideally 3 channel so power your mains.ie wmotoca xpa-3 or similar. ATI 1803 etc
He always recommends items that are way to expensive.I was hoping for something a little more in the sub £500 range
I'm out of touch with hifi I'm afraid,all boils down to budget and if you want 2nd goods.Anybody else got any suggestions?
