Does anyone else that plays in duos/squads find that some people in the team can hear sounds that others can't or just hear them from further away?
Using some Steelseries Arctis 3 (not using the 7.1 stuff) connected via an Asus Xonar U5 USB soundcard (also with surround disabled).depends how you got your pc set up.what you listening to sounds through.
Sometimes it is, but other times we're both alive (for a few minutes, then the people he can hear that I can't kill us).Are you on about if they are dead and spectating? You can definitely hear a lot more than what your partner can, my friend or I will often call out peoples positions depending on who is dead. Think it's a bug.
I don’t think anyone, other than his ‘character’ thinks he’s pro in any way. He’s an entertainer - whether good or bad at that is subjective but it’s what draws viewers to him. Not his ability (or lack thereof)Doc is definitely not a pro. He sucked so hard at charity event. It was sad to watch... He basically is all talk same as his "created" character... Had a chance to prove himself. Choked...
Fog on the original maps?Patch #19 notes, looks to be the best patch in a long time
https://steamcommunity.com/games/578080/announcements/detail/1696054587148780477
don't agree with that one. eliminated teammates should not be able to interact with the game other than spectating and chatting.Eliminated teammates can now place markers on the map.
could you not always do that before? i'm sure i could.Now you can move your mouse cursor to another monitor when the system menu, world map, or inventory is opened, if you use multi-monitors
