- 1 Dec 2015
Glad to hear it's all sorted, slap some pics up when it's done
It's just on the stock cooler for now, and I don't have the 140mm in yet, so really not going to try pushing it. Would like to try and get the ram upto speed though.
Went for the vulcan 3000mhz, since the 3200 dark was out of stock. Saved some, lack of patience, but given the red hot friday deal, it was a big saving to take it now.
. I'll do some more reading, ready for later today when I'll actually sit down and have a go
.On the memory clocking, could I use the gigabyte easytune software?
https://www.gigabyte.com/FileUpload/global/Microsite/369/images/system-tweaking.html
Haven't stress tested though, what would be the best way to do that?Can I just ask what is the issue with fast boot? Cheers.at stock speed and 3000hz, should just be able to enable xmp and off you go
disable fast boot if its on
Ditto for that question. I didn't even check. 1 task at a time for me, and that was the ram that time.
Done the ram, easy enough to set the xmp profileHaven't stress tested though, what would be the best way to do that?
I've also worked out why I likely wasn't getting any cpu fan speeds in the bios (that was a worry), but on a closer look, I'd plugged the cpu fan into cpu_opt rather than cpu_fan, so whilst it was spinning properly, it wasn't recording the speeds correctly.
